I tip my hat to Cig. He’s 100% correct and provides an extremely articulate explanation to boot.
The platinum-palladium alloy coating the ceramic hineycomb inside the cat converter does one thing only: when heated, as Cig said, it seperates the oxygen atoms from the nitrogen atoms in the exhaust stream, the NOx having been created by heat and pressure during the combustion process. The freed oxygen atoms then become available for
(1) the carbon monoxide (CO) molecules to grab an extra oxygen atom and become CO2
(2) unburned hydrocarbon molecules (HC) to split and grab oxygen atoms (the so-called “second burn”) and become CO2
(3) excess now-freed oxygen atoms to flow out as harmless oxygen
Thus, the exhaust out of the cat converter contains higher levels of unbonded oxygen atoms (actually, diatomic oxygen molecules are also present).
The downstream sensor simply measures the amount of oxygen in the converter’s output, just as the upstream sensor does, and the ECU compares it with the oxygen levels being detected in the upstream sensor. If the leves aren’t sufficiently different, it trips a code.
As Cig clearly said, the only source of heat that the converter has is the exhaust stream. It simply sits there and gets heated up. Platinum-palladium’s catalytic action is directly related to its temperature and its surface area, so it needs to get hot to work. And a catalyst by definition effects change without itself changing. The platinum-palladium never changes. It’s effectivity does, however, get degraded if it begins to get coated with exhaust byproducts. It needs to directly contact the NOx molecules to work, and contamination reduces the direct contact.
The upstream sensor does, in fact, affect trim levels. But the only affect it has on the catalytic coverter is if it’s providing an inappropriate signal and causing excess fuel to be delivered (cauing too long a pulsewidth in the injectors), which can manifest itself as carbon residue on the platinum-palladium and adversely affect it’s ability to seperate the NOx molecules into nitrogen and oxygen.
The MAP sensor, the MAF sensor, and leaks can in fact affect proper fuel trim levels and can, by causing desposition on the catalyst, cause the catalytic converter to be unable to its job, but it’s an indirect cause & effect rather than a direct one. The sensor has no direct effect on converter performance, it has no direct control over it.
