I power my backup generator on gasoline, of course that turns into a vapor and transforms from liquid gas, to an actual explosive vapor, Just cause I have nothing to add about gas think you brainiacs might be interested in the 4th state of water, kind of like the 4th tower of inverness, maybe,
You already know that water can have three states of matter: solid, liquid and gas. But scientists at the Oak Ridge National Lab (ORNL) have discovered that when it’s put under extreme pressure in small spaces, the life-giving liquid can exhibit a strange fourth state known as tunneling.
The water under question was found in super-small six-sided channels in the mineral beryl, which forms the basis for the gems aquamarine and emerald. The channels measure only about five atoms across and function basically as cages that can each trap one water molecule. What the researchers found was that in this incredibly tight space, the water molecule exhibited a characteristic usually only seen at the much smaller quantum level, called tunneling.
Basically, quantum tunneling means that a particle, or in this case a molecule, can overcome a barrier and be on both sides of it at once
