@AJ321 What is “Tester’s head gasket fix?” Stuff you buy at the drug store to put in the coolant and he and others swear by it as a last resort try before dumping the engine. I don’t remember the compound anymore but you can do a search here for his comments on head gaskets or he’ll pop in and tell you if you really need to know.
bing
21
Related topics
| Coolant Reservoir doesn't drain back into Radiator | 40 | 377092 | January 31, 2017 | |
| '03 Civic - coolant not returning from overflow container | 21 | 32422 | August 2, 2014 | |
| Coolant Recovery Tank | 11 | 1422 | November 4, 2009 | |
| 2004 Avalon with mystery coolant leak | 32 | 9299 | July 9, 2021 | |
| Bad Head gasket. Is this problem related? Coolant overflow and failure to return to engine.? | 4 | 8805 | March 23, 2016 |
