OBD II code P1784
I have a 1996 Dodge Grand Caravan with a 3.3 and 4 speed auto. I get a P1784 code from my code reader.
I’ve had it kick into limp-home mode on moderately long trips. I think I’ve corrected the leakage that might have existed. P1784 isn’t in the book.
Is there a TSB? What’s this code??? Low Trans Fluid??
I did find fluid on top of the case, behind the crank position sensor once but found no source. Hasn’t happened again but still goes into Limp-Home mode sometimes.
Check this
http://en.allexperts.com/q/Chrysler-Repair-807/2008/7/1997-intrepid-DTC-P1784.htm
