Changing harmonic balancer 3.8
install . put harmonic on has a pin hole for alignment. moment its put on into place it will start to seat into position. Ie only proper goes on 1 way moment it pops on ie spin till it goes in and stops moving. put bolt in and tighten bolt.
Welcome to the forum.
FYI This is an 8 year old post. You can see that from the date in the upper left… Nov '13 was the last post.
Since the issue of removing the crankshaft bolt has been revived, I’ve wondered if the car has a manual transmission, it seems like all you’d need to do is put the transmission in gear, apply the brakes, block the wheels, and ratchet/socket the bolt off. Does that method work?
Yes, it would work.
Well I thought 8 years ago the bolt was snapped? So now bolt head. Thinking of the hard time I had loosening that bolt with the timing chain not intact, don’t think an EZ out is going to do the job. Maybe weld a new nut on if possible.
