I have a 1999 Ford Contour with the V-6 engine. Something leaped up from the road and struck this car's surprisingly unprotected aluminum oil-pan causing it to develop a crack on the (relatively) flat surface on the bottom, causing much of the oil to drip out and intermittently bringing on the dreaded engine oil light.
The Ford dealer wants over $800 to install the superceding-design oil-pan and a corresponding new dipstick(?); independent garages have alleged they can do the job anywhere from $350 (if a used oil-pan can be obtained) to $550. Even the low figure strikes me as a ridiculous price to charge for fixing something as simple and banal as an oil-pan.
When I inquire of the independent mechanics as to the possibility of repairing the existing oil-pan via welding or some such, a couple of them have discouraged this saying that the combination of the hot oil in the pan and its aluminum essence do not lead to reliable, lasting results.
But then I came across this product, HTS-2000 (
http://aluminumrepair.com/index.asp), whose manufacturer claims it yields an aluminum repair superior to welding. Do the manufacturer's claims sound plausible? How hot does engine oil and an aluminum block get, and does this manufacturers' product sound capable of withstanding that (they claim (
http://alu...e_info.asp) it has a "working temperature" of between 717 and 737 degrees)? Do you know anyone who has used this product?
Otherwise, have you ever been confronted with a cracked aluminum oil-pan and, if so, how did you resolve it? The answer is important as I will be taking this car and a trailer 2000 miles cross-country (back to Oregon) shortly and I'd prefer not to suddenly lose all of my oil in the Utah desert 100 miles from anywhere.
0 •
Comments
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeSuggestion, why don't you call the parts department and ask how much the pan cost with the new dipstick. If reasonable, buy it and have an independent install it. Just might work out cheaper.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeThe problem with replacing an oil pan is all the stuff you have to remove to get to it. Some you even have to raise the front of the engine up to replace it. That $350 charge...most of it labor.
The other problem is that there aren't too many aftermarket companies that make oil pans. Just no market in it. It's one of those parts that doesn't break. So you may be stuck with OEM only.
I've never tried the epoxy, but I sure would if I was in your shoes. Doubt there is a better solution.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeA good welder can MIG or TIG weld it and it will be good forever.
It's better that the pan be removed for this procedure.
Aluminum is routinely welded all the time. Being involved in the antique motorcycle world, I have seen rare, pricy, and hard to find engine cases exploded from fatigued connecting rods. These shrapnel cases are MIG/TIG welded back together, main bearing races align bored, and good to go; and they take a lot more of a beating than an oil pan does along with being immersed in hot oil.
If you can't do the work, ask the shop if they will do the pan R and R and then take the pan to a good welding shop yourself.
(That's assuming the pan is not trashed and the problem is nothing more severe than a crack, large or small.)
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeI had a aluminum motorcycle engine case repaired this way. The case was cracked in several places when the drive chain broke for a previous owner. The case was not disassembled and did not leak after the repair.
- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeIn the next time, I might take a safe distance longer than necessary from the vehicle in front if it were a 1999 Ford Contour.
- Spam
- Abuse
- Troll
- Abuse
- Troll
