Join the Car Talk Community!
Discussion Rules
Sign In Register
Buick LeSabre windshield leaking
My 2005 Buick LeSabre is leaking when parked on a hill, facing downhill. The water ends up on the driver's side floor mat near the pedals.
Where could it be coming from? And how do I fix it?
  • Water travels really well without you being able to detect immediately where it comes in. For instance, I had water come into the cabin from a rear tail light once. Perhaps simulate the condition, parking in downhill and hosing it down.
  • It could be the windshield or the drivers door seal. Park the car on a hill and have someone pour water on it with a hose while you sit inside. This way you can see where the water is coming in.
  • My 1996 Buick Le Sabre leaks on the rear right side floor board. It leaks only during Florida monsoons. No one has been able to figure it out. I would guess it's door seals, though it is not obvious -- no tears, loose seal, etc.
  • Does your car have a sunroof? I would suspect either plugged sunroof drains or a leaky windshield.
  • I have a 2000 LeSabre - This summer (while hot and using air conditioning), I had water coming into my passenger side floor area via hear/air duct work. I learned that the rubber "beak" on the end of the air conditioning drain pipe, where the condensate runs out had melted and the opening closed up, and the condensate was backing up into the system. A friend removed the rubber part and water ran out onto the ground inside leak since. According to him, not necessary to replace the "beak", just left the drain pipe open, he knew immediately what to do, said he has seen it often. I do not know if you are located where you have been using air conditioning this time of year...but thought this might help.
    I have also have had a leak around the passenger door seal for several years, when it rains REALLY hard, water comes in on floor mat. Dealership told me they have a "door seal" guy who comes around once a month and does that type of work, for initial fee of $75 just to diagnose, then more for whatever repairs or replacement. I never went.
