1998 Toyota Sienna Drive cycles
1998 Toyota Sienna with 209K miles recently needed its emissions tested. When i took the vehicle into get tested it passed the emissions portion but failed the test because of the check engine light. Took the van in to get an O2 sensor replaced and check engine light was turned off and everything appeared OK.
When taking the van into get tested again I was informed that in order to replace the sensor the mechanic must have reset the electrical system (or something along those lines) and that the emissions couldnt be tested because of this. According to the emissions tested I would need to reset each of the vehicles drive cycles before it could be properly tested. After attempting to reset them all one afternoon I took it back in later that week to get it retested but they still said that they werent reset and couldnt identify which ones I needed to target and that the only advice they could give me was “Drive around until the check engine light turns on then drive until it turns off again”
This was about two weeks ago and havent seen the check engine light come on or anything other siginificant indicators. My issue with this is that I need to get the emissions passed ASAP and the fact that imperfect science that is reseting drive cycles is really putting a kink in the those plans.
Any advice on what to do would be greatly appreciated.
Thanks
This is the generic drive cycle for your vehicle:
Turn ignition switch on without starting the engine.
Turn the AC on to the high position.
Start the engine and immediately start driving the vehicle.
Do not allow the the throttle position to go over 30%.
Do not accelerate suddenly.
Drive with a smooth throttle operating.
Drive the vehicle at 43-56 MPH for 10 minutes straight.
Stop the vehicle and allow the engine to idle for 5 minutes.
End drive cycle.
And if you’re interested in all the gory details, here’s a Toyota TSB for all 1996-2002 Toyotas, titled “READINESS MONITOR DRIVE PATTERNS”.
http://www.watrd.com/work/TSB_EG003-02_(revised).pdf
