Join the Car Talk Community!
Discussion Rules
Sign In Register
honda odyssey - shaking with check engine and VSA on..
2006 Honda Odyssey with about 120,000 miles on it. Check engine light and VSA light came on at the same time. Car vibrates dramatically and has little to no acceleration. Put off the engine and restarted. Car worked fine after that. Has happened twice in the last 2 weeks. Any thoughts on what this might be + what do I need to do to fix it?
  • edited April 2012
    Read the codes stored in the car's computer and post the results here. You can probably do this for free at a local auto parts store.
    Are these the original spark plugs? The EGR passages in the intake manifold could be plugged up with carbon buildup. Is misfire worse while trying to accelerate hard?
    Could be a coil that needs replacing. Could be a sensor.
  • Thanks.
    The car engine light is not on anymore. Will I be able to get a history?
    Yes - these are the original spark plugs.
    Don't know about the misfire - my wife was driving the car both times it happened.
  • You've got to be able to do a lot better with the background info on the vehicle and the description of the problem. On the latter, perhaps your wife should just write up exactly what happened. All we have right now is that these lights came on and the car vibrated and had trouble accelerating. Ok - well, what was she doing when this happened? It all started right when the car was turned on? While she was sitting at a stop sign? Doing 70mph on an interstate? It vibrates while sitting at idle? Or only when....? The car sounds like...? Feels like...?
    This this is also 7 years & 120K miles along in life, and you didn't ever say if it ever got a new set of spark plugs or fuel filter, etc. A fairly detailed idea of maintenance history would be good.
    Some shops will have computer scanners that will pull history codes from the computer, though I don't know how long codes are stored. Auto parts stores will read them for free, but most use equipment that will only pull current codes with the engine light on.
  • Your Honda is going into "limp" mode and has significant issues. 120K miles on the original plugs means you have to a lot of stuff to deal with. The Odyssey tends to have transmission problems as they age. Motor mounts also are weak on this car. So, if you drive it with the "shaking" you could damage the motor mounts and have more problems as a result. Get new plugs, new filters, and have the "codes' read for more direction on what the car needs.
  • Thanks guys. Got the error code from. It is p-2647. As pe the technicial in the pep boys who read the code, this is a honda software issue related to the Technical Service Bulltein #05-019 (from Honda). Is this valid? Any suggestions?
  • I know what that is but you probably will not like it.. Its the VTEC oil pressue switch.. Basically the high RPM cams are staying engaged at low RPM.. The switch that activates them are getting stuck.. Have you had the oil changed recently?? Have you checked the level, becasue low oil can cause the same issue.
    The switch itself is not much money, but the labor to put it in can be. Or it can be the whole soilinoid assembly but that is rare
  • Assuming I am keeping the car, I have to get a timing belt change done anyway. Will that help reduce the labor - or is it completely a different area. Sorry, am mechanically challanged here :-(
  • Completely different, I don't think the sensor is that bad. It's the assembly that really costs. But it's less then a new van. With that said, the others are right. If your trans is original and your motor mounts are original, you may very well look at spending zero and trading the van in. You can easily be looking at 5-6,000 worth of repairs if all these things go bad.
    At least have the motor mounts checked prior to doing the timing belt.
  • Guess what - it turned out to be that i was running out of engine oil. looks like i skipped few oil changes :-(. Weired part is that low oil indicator never went off.
    I put in some oil in the engine, and haven't seen the problem yet in the past 3 weeks.
    Thanks all for help
  • Are you now checking your fluids (NOT just your oil) regularly?
    In addition, pull out the recommended maintenance schedule that came with your owner's manual and bring the car in ASAP to get all the neglected maintenance caught up. At this point you've definitely caused premature negine wear, probably begaun the process of sludgingg up the engine, and severely reduced your engine's life. You'll not get the years of trouble-free service that most of us aspire to. And your engine will probably burn oil now, all the more reason to start checking it regularly. Honestly, I'd suggest an oil change every thousand miles for the next few thousand to clear out the sludge. Perhaps even an engine flush, which is something i RARELY recommend.
    Your poor motor! I feel its pain!
