- Listen
- Our Show
- Car Info
- Buying
- Owner Reviews
- Tom and Ray's Reviews
- Research a Car
- Find a new or used car
- Cars We Hate the Most
- Secret Tricks of Car Salesmen
- Hybrid Vehicles
- Calculator
- New Car Incentives
- More…
- Owning
- Post a Review of Your Car
- Tom and Ray Explain Maintenance
- Check Safety Recalls
- Want To Do It Yourself?
- How To Keep Your Car Running Forever
- Premium vs. Regular
- Change a Flat
- Car Cleaning Tips from a Pro
- Official Car Talk Guide to Jump-Starting Your Car
- Guide to Better Fuel Economy
- More…
- Cars.com Content
- Mechanics Files
- Blogs
- Community
- Fun Stuff
- Store
- Contact
Comments
Does this vehicle have a timing belt??
If so then that should be FIRST...
Transmission fluid is a MUST.
Replace the plugs. Get OEM plugs. NGK are the OEM manufacturer of Honda plugs.
Air Filter is probably a good idea too.
- Spam
- Abuse
- Troll
2 • Off Topic Disagree 2Agree Like- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeIt would be a little bit of a stretch for me to list them all. I am sure others would have a better answer.
Look in your owners manual. Make a list of everything that was supposed to be replaced by 100K and get it all done at once. I would guess that your looking at $1K to $2K worth of work.
- Spam
- Abuse
- Troll
1 • Off Topic Disagree 1Agree Like- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeIf a timing chain...then nothing to worry about until about 250k miles or more. But it'll start making noise to let you know it needs changing.
Denso plugs are good.
You don't need Iridium plugs. Standard plugs work just as well. Iridium and Platinum plugs just last longer.
- Spam
- Abuse
- Troll
- Abuse
- Troll
1 • Off Topic Disagree 1Agree LikeIt will say what brand and part # plug to get. It will likely have Denso and NGK #'s.
Denso or NGK are equally good, just get exactly what the label says.
Change the fuel filter and get the brake fluid flushed.
You might be able to fine an online maintenance guide at honda.com
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeHowever, before going too deep into this thing monetarily I would recommend 2 things. One is to check for oil sludge/coking problems and the other is a compression test; each possibly being related to the other. The compression test means the spark plugs come out so replace them at that time.
The easiest way to check for oil sludge/coking is to remove the valve cover (this is where valve lash inspections factor in) and to probe the bottom of the oil pan with a wire loop during an oil change to see if any tar like substance is stuck to the loop.
If there are signs of oil related problems and/or compression problems then I wouldn't get too enamored with the car. The fact the seller was honest enough to tell you they had done nothing to the car may not mean much. That can also be, and often is, a way of saying that they recently discovered an expensive headache and is their way of playing dumb.
If you have a compression test run you should see readings of 180 PSI and above on all cylinders.
- Spam
- Abuse
- Troll
