Join the Car Talk Community!
Discussion Rules
Sign In Apply for Membership
Would you trust this clutch?
Hi all, the 99' VW I just bought has an odd feeling in the shifter every now and then. It happens about 50% of the time and is most noticeable in the lower gears. When shifting there is sometimes a little resistance in the shift lever when going into the next higher gear. This is sometimes accompanied by a "thunk" sound in the transmission.
The clutch doesn't slip when I give it some gas and the "thunk" sound isn't really loud, just worrying. It doesn't do it all the time in any particular gear and I can't detect a pattern of any sort.
I don't know if this is related or not but the shift lever itself is rather "floppy." I've never had trouble finding the gears but you can move it around about 3/4" in all directions while it's in gear. I read in the manual that you shouldn't rest your hand on the shift lever because that can cause wear, perhaps the previous owner did that a lot?
According to the repair records the clutch was replaced about 11k miles ago and the parts listed on the invoice are a clutch kit, crankshaft seal, flywheel, and cv joint gasket.
Is this something that should be looked at by a pro?
Thanks!
Comments
Sign In or Register to comment.
