There is an answer to a question in the latest Consumer Reports that has me confused.
The question is "Is a certain percentage of synthetic motor oil required for an oil to be called 'semi-synthetic'?"
The answer is "No, standards for oil are based on performance, not formula."
First of all, I don't think they answered the question.
But if they did...
Maybe it's just me. It is early in the morning here in California. I've often read here that some vehicles require synthetic oil. If that's true, how could the answer in Consumer Reports also be true?
If CR is correct, anyone could just use mineral oil if it is the required oil weight for their vehicle and is API certified.
What am I missing?
Comments
As to their second comment, I interpreted what they said was about API classification, which can be met with selected mineral oils, as well as synthetics or semi-synthetics. API classfications cross all oil types.
All of that said, you still have to meet the oil requirements as specified in the owner's manual during the warranty period.. In many cases (BMW & VW comes to mind), only synthetics meet their standards. In my case, that means I will run a synthetic oil while my Subaru is under warranty (Subaru highly recommends this, but does not clearly specify/require a synthetic). Then I will choose whether to continue the regimen, or not. For the most part, I am running synthetics or semi-synthetics anyway, based on my oil choices for my other vehicles.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeYes, they did answer the question, but--The Devil is in the details.
If a motor oil is labeled "synthetic", then it is, by definition, 100% synthetic.
However, the question concerned "semi-synthetic" motor oil, and in that case, the exact proportion of synthetic oil to mineral-based oil varies from one brand to another.
If you want an analogy, think about the difference between fruit juices and "fruit drinks".
The fruit juice is 100% juice, and the "fruit drink" might have anywhere from...perhaps as little as 5% juice... to as much as...maybe...50% juice.
The bottom line is that, if your Owner's Manual specified synthetic motor oil, you should not be using "semi-synthetic".
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeI don't see the answer the way you do. A correct answer would have been - 'In order for oil to be called semi-synthetic. it has to be at least ___% synthetic oil. They seem to be answering a different question than the one that was asked.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree Like"'In order for oil to be called semi-synthetic. it has to be at least ___% synthetic oil."
Please fill in the blank!
What is the minimum percentage of synthetic oil that is required in order for an oil to be called semi-synthetic?
Inquiring minds want to know.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeThere is no standard as to what ratio of Synthetic/Regular Dino oil is. If there's ANY regular dino oil then it's semi-synthetic.
Most of the semi-synthetic oil is about 20% synthetic.
- Spam
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeThen wouldn't you agree that CR should have given your answer rather than referencing API performance standards? Or at least they should have included the information you gave with their answer?
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeIf a car maker has an engine he is worried about, or he wants to extend oil change intervals to 7500 miles and beyond, then they usually specify a specific brand of synthetic oil (100% synthetic).
I see NO benefit in using a "synthetic blend" motor oil over a 100% mineral product..If you feel a synthetic product offers you some benefit, then step up to a 100% synthetic product and get the full benefit!
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeThere are a few oils that are labeled "semi-synthetic." 'Lucas' is one of those brands you would see if you googled it. But it's really just a matter of how the producer of the product wants to describe it. "Semi-synthetic" & "blend" mean the same thing.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree Like"Synthetic Blend" motor oils are a USELESS product. The consumer has no way of telling what the "blend" is, what the percentages are, or what the seller was trying to achieve by mixing mineral and synthetic base stocks. It's all VooDoo Magic nonsense. The manufacturer knows EXACTLY what it is..An enhanced price-point for a product that costs little or nothing extra to manufacture. The consumer is enticed by the word "Synthetic" to purchase a product that for all he knows is 95% Mineral Oil...
- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeWhat if I want to run 0W-30 oil, which isn't available as conventional, but I want to spend less $ than full synthetic?
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeI have a feeling the price difference between mineral oil and synthetic oil will continue to narrow until price is no longer a factor when making a purchase decision...
I LOVE the Motor Oil Isle in a Super-Wally World....It takes me about an hour to make up my mind! What a play-pen for Lube Phreeks...
- Spam
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeThe present definition of blend or semi-synthetic is all over the map, and of dubious value if it is a 5W30 or heavier.
- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeThe answer should have been, "Any oil that contains a very small or very large amount of synthetic oil can be called 'Semi-Synthetic' because there is no established standard."
If CR had been more clear with their answer, I would not have been confused.
I feel better now.... :)
- Spam
- Abuse
- Troll
