The puzzler got me thinking about flat fan belts. They are used today where ever ultra high speed and low friction are required. (They are the blades in bandsaws, for example.)
Ever wonder about the contour of the pulley face, and what keeps the flat belt centered on the pulley?
For the curious, the answer is
here.
BTW, the story Click & Clack described actually occurred in WWII. The name of the German soldier who came up with the idea, and whose name is forever associated with the technique for reducing fan belt wear, was Obergefreiter Moe B. Usse. He was later
stripped of his awards after caught carrying gasoline in a Klein bottle (which he bought at M. C. Escher und Söhne).
Comments
- Spam
- Abuse
- Troll
Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeHonestly, I never have wondered!!
- Spam
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeI have an enquiring mind.................
- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeTwisted belts were often used on old farm equipment, either for reversing direction, to reduce effects of wind whip, or to increase friction.I have seen this at antique farm equipment shows. Google tractor thresher twisted belt for some YouTube videos.
One fellow in Maine had a 6 hp gasoline engine attached by a flat belt to a table saw. (Apparently it was a short belt.) While applying belt dressing to the inside surface, a dangerous job, he wondered if he could turn the belt into a Mobius strip and apply belt dressing only to the upper surface. It is easy to do this by removing the belt lacing pin and giving the belt a half-turn before reinserting the pin..
Read his story here
Either that guy is lying, or the twist does not "walk around" even a short belt as you claim.
- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree Like@Mechaniker's link mentions putting the twist on the slack side of the pulleys instead of the tension side, which makes sense. Either way, the twist could not move to the other side.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree Likehttp://en.wikipedia.org/wiki/File:AHW_Kammgarnspinnerei_Pfaffendorf_Leipzig_um_1925.jpg
This was the norm intextile mills for a generation or more....much more. They were flat leather belts.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeFirst, assume that a belt wears thin until it fails. Let"s take for an example a belt which fails at 100 hours when it has worn to 50% of its original thickness. The belt is formed as a moebius loop and a point on one side is marked "A". After it has run 100 hours the point marked "A" will be found to have worn down only 25%. Unfortunately, the belt now has only one side "A" so the "other" side of point "A" will have worn down 25% also. The belt, worn 50% total, will fail.
- Spam
- Abuse
- Troll
