Last Car Talk one of the callers had a problem where his spark plugs were popping out. Tom and Ray said the reason was that they were'ent installed tight enough in the first place.
Home handyman mechanics: Don't interpret this as a message to tighten the spark plugs as much as you can when you install them. Use a torque wrench and tighten them to specification, no looser, and no tighter. If you don't have a torque wrench, buy or borrow one. Too tight is as bad or worse than not tight enough.
I always coat the plug's threads with a very thin layer of moly grease prior to the install. Very thin layer, just enough to coat the threads and no more. You don't want grease getting dripping onto the firing tips of the plugs. I find doing this makes it easier to put them in with the correct tightness, and more importantly, to take them out at the end of their life span.
Comments
I've NEVER EVER used a torque wrench to tight down spark-plugs. I have one...just don't use it for this. And NEVER EVER had a problem. I've never used grease...but have used anti-seize (especially on aluminum heads).
- Spam
- Abuse
- Troll
Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeWe've had long debates about the use of torque wrenches for plug. For many years I never used one, but I go back before aluminum was everyehere. Now, after having seen so many complaints about stripped threads, I believe in them and use one myself. Some here, very experienced people, don't believe in them.
I never use lubricant or antiseize on plugs. As a matter of fact I'd wonder if a coating would adversely affect the ability of the treads to ground out properly by creating a resistive junction. Sparplugs do electrically ground vis their threads. Like others, I've never had a problem.
- Spam
- Abuse
- Troll
- Abuse
- Troll
Off Topic Disagree Agree LikeI think the reason many of the blown out spark plugs we hear about are on Fords is because the Triton engines are notorious for it due to their rather shallow plug bungs. Not all of them have been Fords, though. Remember that Toyota (Matrix, I think) the dealership replaced the entire engine in over this?
Like Mike, I am a believer in anti-seize compound, as well as dielectric grease on the wires. Both make future disassembly go easier.
- Spam
- Abuse
- Troll
Off Topic Disagree Agree LikeMany years ago I had a 71 VW Bus and every time I changed the plugs they felt like they were cross threading or stripping. Never did though. I knew guys who raced with flat 4 VW engines and the first thing they did was drill out the plug holes and put heli-coils in. Made changing plugs much easier.
- Spam
- Abuse
- Troll
