Is it safe to clean your catalytic converter by pouring some lacquer thinner in your gas tank and running the engine for about 150 miles as Scotty Kilmer suggests in this video?
The p0420 code came on about a month ago, and it goes off and on intermittently since then - I'm hoping that that means that the problem is fairly recent and, if this lacquer thinner thing works, will get rid of the impurities that are launching that code.
I need some reassurance or some advice before I do this.
Thanks!
0 ·
Comments
- Spam
- Abuse
- Troll
0 · Off Topic Disagree Agree LikeBTW - often on an OBD2 system, a catalyst code will get set when the real problem is that the oxygen sensors are getting old and slow to respond. Do your oxygen sensors have more than 100k miles on them?
- Spam
- Abuse
- Troll
0 · Off Topic Disagree Agree LikeIf your vehicle has over 100K miles, try changing the rear oxygen sensor since that's the part that is generating the code...
- Spam
- Abuse
- Troll
0 · Off Topic Disagree Agree LikeYou do it first:)
- Spam
- Abuse
- Troll
0 · Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
0 · Off Topic Disagree Agree LikeI knew it was too good to be true. What about cat cleaners? I haven't really researched them, but are there any that might do the job?
Thanks!
- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
0 · Off Topic Disagree Agree Like--If you had the codes read, you might be able to tell.
- Spam
- Abuse
- Troll
0 · Off Topic Disagree Agree Like"--If you had the codes read, you might be able to tell. "
Actually NO...When you read the codes...if an O2 sensor is bad it'll give a false reading to the OBD-II system. If a cat is bad...the O2 sensor will set the same error to the OBD-II system. You can't tell what's bad by the reading. All you know from the reading is that the O2 sensor is saying somethings wrong. From there you have to do more tests to determine if it's the O2 sensor or it actually is the catalytic converter.
- Spam
- Abuse
- Troll
