Our mechanic found multiple flat spots on my daughters car during the last maintenance run. Looking through your FAQ and discussions I noticed a lot of skids and brake locking going on. My daughter doesn't drive like that...she's too afraid to. (Giving the benefit of the doubt.) Plus I would figure the flat spots would be on more tires. We queried WalMart (where we bought the tires) if it could be a defective tire. The manager said it was due to bad shocks. Now, I'm no mechanic but that just doesn't make sense! What do you guys think?
0 •
Comments
Has she had to lock up the brakes in order to avoid an accident?
BC.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeWhat kind of tires are on it?
Worn out shocks can and do cause "flat spots" to war in tires.
But so can poor balance, as well as poor quality tires (I personally have had problems with Continentals).
And so can worn suspension components.
Go to a good, reputable chassis shop and have them get the car on a lift and take a look. If they too say you need shocks, have them show you why. Have them show you the abnormal wear.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Likedo a bounce test on each corner of the car. does it rock like a boat on water or is it stiff and comes back to normal ride height within 1 or 2 oscillations? if it rocks like a boat on water you need shocks. if one is leaking you need shocks.
- Spam
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeWhat your daughter has is "irregular wear". The trem "flat spots" or "cupped' is sometimes used to described this - and unfortunately, those terms will lead folks to a wrong diagnosis.
Irregular wear is usually caused by misalignment and aggravated by insufficient rotation practices and insufficient inflation pressire. So the first thing to do is to get an alignment.
- Spam
- Abuse
- Troll
- Abuse
- Troll
