Join the Car Talk Community!
Discussion Rules
Sign In Register
After filling up my car sputters and stalls 2-3 times
yea i have a 09 chevy aveo5 and just recently when i fill up my car it sputters and stalls 2-3 times before it stays on, i never let it get completely empty could this be a air in my gas line?
  • edited March 2011
    No, you do not have air in your gas line.
    But--how do you fill up the tank?
    Do you stop when the pump clicks off for the first time?
    Or, do you do the click-click-click maneuver to force additional gas into the tank?
    If your answer is the latter of the two situations, then I suspect that you have contaminated the evaporative emission system's carbon canister. Or, you might have a defective purge valve in the evap system.
  • edited March 2011
    Is the gas cap on tight? Is your check engine light on?
  • edited March 2011
    yes the gas cap is on tight thats what the mech. told me the first time,and yes the light is on
  • edited March 2011
    yes i do the "click click click" but not anymore, what should i tell the mech.?
  • edited March 2011
    Go to your local Pep Boys or Autozone and have them run a free OBD diagnostic check. They can pull the error codes and help narrow down the problem.
  • edited March 2011
    Simply describe the symptoms to the mechanic.
    If he is worth his salt, he will know what to look for.
    In case his eyes glaze over when you describe the problem, you might want to say that you have been told that the problem could lie in the evaporative emissions system.
    If it turns out that my diagnosis is correct, I hope that you realize that you really shot yourself in the foot with that click-click-click routine. Unless you are about to drive across the Gobi Desert, there are more than enough gas stations around so that you don't have to worry about being able to drive--perhaps--five miles further before the tank is empty.
    On Toyotas, replacing the carbon canister runs ~$300--or more, but I have no idea of what it might cost on the Aveo. Hopefully, it will be less.
    Even if you don't need to have the carbon canister replaced, do yourself a favor and stop filling the tank when the pump clicks off for the first time. The Chevy Aveo has a pretty poor reliability record, and doing things like you have been doing will definitely not help the car.
  • edited March 2011
    to add on to twotone here when i first brought it to the dealer they did a diagnostic and i came up that my gas cap was not on tight, so 3 days later the light came back on, so went and bought another gas cap and reset the switch my self, the next morning the light came back on
  • edited March 2011
    Pep Boys?? Good Luck...But while you are there, ask them how much a new carbon EVAP canister costs..Yours is wasted from over-filling your tank. Now it can't absorb the vapors generated when you re-fuel and these vapors flood your engine causing the difficulty at start-up..
