Back again with another question.
CAR: 1999 Oldsmobile Cutlass, 137k miles, full tune-up late December.
BACKGROUND/HISTORY:
Replaced 12 year old tires in November, guy who sold them was nice and accomodating, but definitely not a mechanic. Front right wheel frozen on, the guy smashed it off with a metal mallet to replace it.
PROBLEM:
About 1 month later, a whistling-sounding noise was coming from what I thought was front right of engine. Mechanic fixed a vacuum leak late December, I thought that was cause. Seemed to be noticeable more during acceleration, cold weather, or after reversing with wheel turned.
MOST RECENT DIAGNOSIS:
Mechanic just told me he believes front right wheel bearing needs replacement. He also noticed another clunking noise from same area, believes it can also be fixed with wheel bearing replacement. Quoted $200-$300 for part, $80 for labor. He's a trustworthy and legitimate mechanic, particularly because he has no problem having me bring in the part from elsewhere and he'll install.
QUESTIONS:
I can find these parts as cheap as $40, why is he quoting $200-$300? Am I looking at parts with terrible quality? What is a safe bet brand to buy wheel bearings? Is it worth it to buy wheel bearings with a long lifespan if the car itself is getting pretty geriatric?
CLOSING:
I appreciate all your responses and help in advance.
0 •
Comments
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeQuality wise, I have had the best luck with hub assemblies from CarQuest and NAPA and the worst luck with Advance Auto Parts I never really tried the other cheapo stores like O'Reilly or AutoZone since I got tired of replacing stuff for free. This is a type of part where you truly get what you pay for.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeA failing wheel bearing is quite easy to diagnose if you're a competent mechanic. Labor charge sounds reasonable. A $250 bearing/hub assembly is probably a quality part like AC Delco or National. With a good warranty. That $40 bearing is probably an "offshore" brand. It too probably has a warranty, but that doesn't make it a good part. That just means that the parts store will give you another one when that one fails.
Don't bring your own parts to your mechanic. The fact that he has no problem with you doing that is an indicator that he has no idea how to run a business. Don't take advantage of his shortcomings.
- Spam
- Abuse
- Troll
