I have been having this issue in driver front side since Feb. 2010. I've had the ABS sensor and bearing in this wheel replaced twice; also all 4 wheels' brake pads, rotors and caliphers replaced; parking brake replaced. My mechanic (not dealer) is master mechanic and has 3 other mechanics in a forum working on this - no luck yet. Also there was an issue with wiring for the AC compressor which run beside/near the sensor - it was worn and mechanic thought it was arcing over and making sensor go off. I get lights daily, plus the grinding/grabbing of the brakes. Does anyone think this might be computer malfunction, i.e. sending false signal to ABS system? My mechanic is going to try to find used one to see if it helps. Any suggestions by anyone would be so appreciated. About to drive it off a cliff and I live in North TX - no cliffs nearby! thanks!
0 •
Comments
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeIt is possible to end up with tires of different diameter - even if they're the same size tire - that trigger ABS activity.
I don't think this is very common, but I have experienced it myself (and on a GM vehicle). In my case it was all very low speed ABS activation.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeThe harness part numbers (R & L available) are listed and instructions for splicing.
Don't know if this will fix your problem, but you do need a technician that can access and use the bulletin and properly diagnose and resolve this problem.
CSA
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeFor certain problems, a GM dealer might be the best place to go. This could be one of those.
CSA
- Spam
- Abuse
- Troll
