I have a 2003 Dodge Neon with about 95K miles on it and this has not been my summer for car repairs. Just yesterday the check engine light came on so I took it to the shop, and they said that the catalytic converter needed to be replaced (quoting $765.00). I generally feel that the Conrad's I take it to does good work, but I'd like to get a second opinion from my parent's mechanic (and the guy who sold me the car), who is about 20 miles away on city streets. Can I drive it there safely without doing more damage to the car?
0 •
Comments
The second opinion from another knowledgeable shop should confirm if it really is the converter, and you should get a price similar or less.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeBy the way, depending on the trouble codes, it could just as easily be the rear oxygen sensor, which is the sensor that probably caused your light to come on..Post the code if you know what it is..
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeI will admit I recently drove 1400 miles over a few weeks with a Check Engine Light on. Interestingly enough I was going to shop to get checked out and it finally went out as I was leaving my house. It has not appeared since.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeBut first, on the way to the parental mechanic, if there is an Autozone near you, go there first and ask them to check the code for you. The chain has recently updated its diagnostic capability and might be able pinpoint the exact repair. It helps a lot if you know what you want a mechanic to fix and get a price to fix it up front. GL.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeAnytime you get a CEL and take it to the shop, it is a good idea to get the actual codes. They will be in the format [P1234] That provides a lot more information than "It's the converter" there is no code that says it's the converter. That is someone's interpretation.
- Spam
- Abuse
- Troll
