Join the Car Talk Community!
Discussion Rules
Sign In Register
2001 Dodge Caravan Sport - Transmission Speed Sensor Problem?
2001 Dodge Caravan Sport. Check engine light is on....Sometimes the transmission will not shift into higher gears. Seems to be more prone to not shifting when hotter outside. Typically after setting overnight, shifting is fine/smooth but by afternoon, especially on hot days, shifting will not happen (On cool days/winter, shifting without problem). Fluids are fine. Van has check engine light on but code from auto zone read was useless (related to brakes per attendant)...does this sound like a sensor problem, e.g. transmission speed sensor and how difficult is this repair?
  • edited June 2010
    A speed sensor issue would cause the computer to put the transmission in limp mode. From what you are describing, you are not in limp mode. More than likely you have an internal transmission problem. The first thing to do is check the fluid level and condition. Make sure the transmission is at operating temperature and the van is on a level surface with the engine running when checking the fluid level. Next thing, you need for a transmission shop or a shop with a high end scanner to scan the TCM (Transmission computer) the transmission computer will display very important information about the transmission such as the CVI (Clutch Volume Index) values. This is very helpful in determining things like broken snap rings in clutch drums and worn friction elements and slipping clutches. A diagnostic needs to be done on this trans. How often has the transmission been serviced?? Also, if you need to top off the fluid, use ONLY ATF+4 fluid.... NOTHING ELSE!!!!!!
    Post back with the results of the scan and about the fluid level and condition.
