Hi!
I have a 97 Toyota Corolla at 57,000 miles. I had decided that it was time to change the timing belt (for the first time for this car) and took it to a mechanic.
After timing belt was changed, I start hearing louder noise from the engine compartment. The noise sounds like strong wind from engine. The wind-like noise only happens when I am accelerating from 0 to 20-30 mph. If I accelerate from 30 mph to higher speed or drive at constant speed at 20-20 mph or higher, I do not hear any unusual noise from the engine. If I push the accelerator and increase RPM of the engine while the car is in ?neutral gear?, the engine sounds just normal.
In addition to unusual engine noise during acceleration, I start hearing vibrations coming under the hood from the passenger side of the car. The vibration noise happens only while I am driving. I would really appreciate if any of you could comment on my car problem. I do not have enough money to take my car to a dealer. Thank you very much for your time.
~eyigit
0 ·
Comments
Does the engine idle smooth; and I'm talking glass smooth with no stumble, etc?
You might consider having a parts house like AutoZone scan your car for any codes. If something was not aligned properly during the belt change it's at least possible a code could be set. They will do this for you free and it only takes a few minutes.
Wished I could be precise on this but there is just no way of knowing. Even though your car is aged it only has 57k miles and the engine should be in as new condition with no noises or vibrations.
Wild guessing, I would say that it's at least possible that something is not aligned correctly; camshaft, balance shaft, etc.
- Spam
- Abuse
- Troll
0 · Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
- Abuse
- Troll
0 · Off Topic Disagree Agree LikeCheck the air cleaner box, its fasteners, and the passage from the air cleaner box to the engine. It is possible that something was not connected or was not connected properly. That could account for both a "wind" noise and both vibration under the hood.
- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
