I'm looking for a replacement radiator for my 2000 Ford Explorer, 4.0L V6 SOHC. The current aluminum radiator with plastic jugs is leaking from one of the jugs. Past experience has shown that these radiators usually last 7 to 10 years before they begin to leak. I've had good luck in the past replacing them with a brass replacement, but was told this isn't advisable with newer cooling systems. Why?
I once had an aluminum and plastic radiator repaired by replacing just the leaking jug, only to have the other one blow out a few months later. I was able to find a brass replacement radiator for that car, a Mazda Protege, and it outlasted the rest of the life of the car. I also have an '88 Toyota Supra, and it's original radiator also failed, this time at the 8 year mark. It was replaced with a brass one, and I still have that car with no radiator issues.
I know it cannot be an interaction with the newer long-life coolants. I've used these coolants for years in my Supra and Celica with brass radiators and no problems. And these engines have aluminum heads with cast iron blocks, just like my Ford. So, what's the real issue? Why would a brass radiator not hold up on my Ford?
0 •
Comments
WIKI
A sacrificial anode, or sacrificial rod, is a metallic anode used in cathodic protection where it is intended to be dissolved to protect other metallic components. The more active metal is more easily oxidized than the protected metal and corrodes first (hence the term "sacrificial"); it generally must oxidize nearly completely before the less active metal will corrode, thus acting as a barrier against corrosion for the protected metal.
"Galvanic corrosion (some times called dissimilar metal corrosion) is the process by which the materials in contact with each other oxidizes or corrodes. There are three conditions that must exist for galvanic corrosion to occur. First there must be two electrochemically dissimilar metals present. Second, there must be an electrically conductive path between the two metals. And third, there must be a conductive path for the metal ions to move from the more anodic metal to the more cathodic metal. If any one of these three conditions does not exist, galvanic corrosion will not occur."
Hope this is a jumping off point for a solution to your question
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeThanks for responding.
- Spam
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeWith an all copper radiator, the core and tanks are made from the same material and are soldered together, so the coefficient expansion rate is the same. So no leaks.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeI've had previous problems with these plastic and aluminum radiators, and have replaced them with brass in at least three of my previous vehicles, all Japanese makes. Since I tend to keep my vehicles for extended periods of time, like my '88 Supra and '92 Celica, getting replacements that last is important to me. This same radiator man admitted that the plastic/aluminum radiators tend to only last for 7 to 10 years, which matches my experience. He was unable to tell my why the brass radiators don't last in some applications, and I was hoping for some sort of explanation from some of the better minds on this site. Do you have any thoughts on why a brass radiator wouldn't last in a 2000 Explorer?
I keep up with maintenance, and flush-n-fill the cooling systems every 5 years. I started doing that 10 years ago when I switched to the long-life coolants. Before then, I stuck to a two year schedule. My vehicles all call for glycol-based coolants, and I typically use Prestone.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeNot that I actually know...
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeThe other half of my 2 cents is that a plastic/aluminum radiator is much cheaper and easier to manufacture; which is it in a nutshell.
I do some machine work on the metal lathe and mill and cringe whenever I have to buy a piece of brass stock. The last piece I bought from the aircraft salvage (about 8" long X 2" in diameter) set me back about 25 bucks if I remember correctly. It's pricy.
A couple of years ago someone broke into a local scrap iron building one weekend by cutting a hole in the wall. They used the forklift to load several barrels of brass scrap onto a trailer or truck and those few barrels were valued at about 5 grand.
- Spam
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeI have a couple of '97 BMWs that go through plastic radiators on a regular basis. I can get 100% aluminum 'high performance' radiators for them ($$$), but I have looked in vain for brass radiators to fit them.
- Spam
- Abuse
- Troll
