Expedition No Heat - heater control valve.- where is it
I have a 99 expedition (5.4 V8)with front and rear heat. The hoses going through the firewall and to the rear are both cold to the touch when the car is warmed up. I am hoping the problem is my heater control valve that allows coolant to flow through the heater cores. All the auto stores sell one but I can’t find it any where in the engine compartment unless it is between the engine and fire wall. Can any one send me in the right direction and tell me whee to find the valve.
Thanks,
I see none. All elecrtic blend doors. You should have coolant flowing continually.
You have a flow restriction somewhere.
The previous answer is correct. The Expedition does not use a heater control valve to regulate flow through the heater core. Ford did do this on the later model Explorers, but not the Expedition. The Expedition uses the same plenum box/heater core as the Ford F150 pickup trucks and as the Lincoln Navigator, so any information you find on either of those models will be directly applicable to the Expedition.
It sounds like the immediate problem is that the two heater cores are not heating up. You need to check that the radiator is full, not the overflow tank, the radiator. Open the radiator cap on a cold engine and check the level. If air gets trapped in the radiator, it can have significant impact on heating. If the levels are OK, I’d try a good radiator flush next. Prestone makes a good diy kit and has chemicals to do a thorough clean. Any oil change franchise should also be able to do this. If it’s just the heater core, you can disconnect the two heater hoses and flush both cores independently with a water hose and hose repair connector. You should be able to feel the two heater hoses from a cold start and feel the hoses warm up at about the same rate and get uncomfortably hot.
It’s actually more common for the problem to be with the blend door system. This door directs the air flow through the heater core and regulates the temperature of the air flow. It’s common for this door to break, losing control over heat. The door is on a vertical axis(like your front door) and can swing back and forth at random or wedge in a set position. It’s an expensive repair to remove the dash and plenum box to get to the door, but there is a diy kit that will let you do the repair without all the work and expense. Check for a video posted on YouTube that will show you how to diagnose and repair the problem. Searching “expedition heater” will get you to the right place.
There is a rear heater control valve check under car middle outside valve is under car before it goes inside car to rear controls water flow to rear heater by a vacuum hose
You replied to an 8 year old discussion
OP only posted once and never returned
I seriously doubt he even has the Expedition, he probably fixed the problem and moved onto another vehicle years ago
