I have a 1998 Jeep Grand Cherokee Laredo with no heat. This is a bad situation in Minnesota in December. The fan works fine. This vehicle has the simple single temperature control (not the fancy separate driver/passenger). I can make the air even colder by twisting the control. This makes me think I am not experiencing the infamous blend door issue. One other clue is I am hearing a lot of water rushing noise. My current best guess is I need to flush the heater core. Are there any other diagnostic steps I should try?
0 •
Comments
If the engine warms up, but the heater doesn't, then you probably have air in the heater core and it needs to be bled out. I don't know how the Jeep heater is laid out, so I can't help you there.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeFor others reading this, here's a link to further info on blend doors and their replacement:
http://www.heatertreater.net/Grand Cherokee 93-98.htm
Note for 1998 especially, your blend door motor may be located either behind the glove box or just above the transmission tunnel on the passenger side.
- Spam
- Abuse
- Troll
- Abuse
- Troll
