- Listen
- Our Show
- Car Info
- Buying
- Owner Reviews
- Tom and Ray's Reviews
- Research a Car
- Find a new or used car
- Cars We Hate the Most
- Secret Tricks of Car Salesmen
- Hybrid Vehicles
- Calculator
- New Car Incentives
- More…
- Owning
- Post a Review of Your Car
- Tom and Ray Explain Maintenance
- Check Safety Recalls
- Want To Do It Yourself?
- How To Keep Your Car Running Forever
- Premium vs. Regular
- Change a Flat
- Car Cleaning Tips from a Pro
- Official Car Talk Guide to Jump-Starting Your Car
- Guide to Better Fuel Economy
- More…
- Cars.com Content
- Mechanics Files
- Blogs
- Community
- Fun Stuff
- Store
- Contact
Comments
Before replacing the belt after the old one is off, turn the alternator pulley by hand with a bit of side pressure and listen for any scratching/scraping/grinding sounds. (this will indicate possible wear on the bearings)
You MAY have to use a small bar against the alternator to get enough leverage to pull the belt tight before tightening the adjustment bolt.
Don't forget to tighten the bottom mounting bolt too.
Just be careful you don't pry against any part that may get damaged.
When done, start the engine any observe the belt and ensure it isn't slipping.
In a couple of days, with the engine off and ignition keys removed, inspect the belt for tension. (just put a bit of pressure on the belt at the half way point between pulleys, there shouldn't be more than 1/4" of slack)
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Like[Thanks for the details on checking for bearing wear and checking the work a few days later!]
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeToo many different designs around.
A net search may be all that's needed. I'll have a look but can't promise anything.
Sorry I can't be of more help, but hopefully someone (Perhaps one of our resident techs can help you)
- Spam
- Abuse
- Troll
