Please help, I have a 2007 ford five hundred with 60,000 miles, out of warranty. I am having a/c problems. As long as the engine is revving at about 2000 rpm or the car is being driven the a/c cools fine. At idle for any length of time the a/c starts to warm up and gets progressively warmer the longer you sit. To the point it seems it doesnt cool anymore. It warms instantly so I dont think something is froze up, and when I drive it instantly cools down. I have recently had the expansion valve replaced and the system charged, this did not help. The shop were I took it to is aware it did not work, I just have to wait a day or two for the weather to warm back up again and have them take another look at it. They seem just as puzzeled as I am. Any ideas?
0 ·
Comments
- Spam
- Abuse
- Troll
0 · Off Topic Disagree Agree LikeIf the blend door is vacuum controlled it could do exactly what you describe, since vacuum is high at idle and drops off as you open the throttle. At idle the blend door may start moving and direct airflow more and more towards the heater core. When you open the throttle the blend door moves back toward the AC evaporator.
A vacuum leak would explain this, assuming the system is vacuum operated.
Why was the expansion valve replaced?
- Spam
- Abuse
- Troll
0 · Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
0 · Off Topic Disagree Agree LikeMy theory is that the compressor is not pumping enough, and that is why the mechanic was fooled into replacing the expansion valve. The faster the engine speed, the more the compressor will pump. Another thing to check is the engine cooling fan. It should be at full speed at idle with the AC on.
- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
