For the past month, intermittently, my mechanic (a good mechanic) has been trying to figure out what is causing my 2002 subaru forester to surge when when stopped, hesitate intermittently when stepping on gas pedal and generally run crappy. He's
1. replaced the fuel filter, run scans on the check engine light (says oxygen sensor is wearing out - he disconnected it as a test and still runs crappy)
2. checked out timing belt (is ok - put in new one 2 years ago)
3. replaced pcv
4. replaced temperature coolant sensor
5. (check engine code also came back for fuel trim problem - but Subaru doesn't have mass air flow sensor)
This car does have higher mileage than average - 150k
Help!! my mechanic is about to throw up his hands and I need my car back!
0 •
Comments
I would suggest that he start to focus on the IAC and/or the MAF sensor. At least that would be my next step(s).
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeHe replaced the fuel filter, but did he run a fuel pressure test on the fuel system while the engine was surging?
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Like- Spam
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeI think perhaps the engine does have a MAF. On my Subaru the MAF is adjacent to the air filter box.
I'm in agreement with VDCdriver's advice about the MAF or the Idle Air Control.
In addition, if the O2 sensor is not functioning correctly it should be replaced. The O2 sensor(s) are very important for correct engine operation. They DO wear out with time.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Likehttp://www.import-car.com/Article/43516/subaru_tech_tip_diagnosing_idle_surges_on_legacy_models.aspx
My 2000 Subaru Outback Sedan just starting acting up with the same problem so I'm goint to try that. This has to be related to a sensor providing bad data to the computer about airflow or air/fuel ratios. Somewhere there is a sensor that is only working correctly when the RPM climbs over idle... thus it's working well enough for the computer to believe and react to the data from it. While I have it open, I'm also going to throw in a new air filter.
- Spam
- Abuse
- Troll
- Abuse
- Troll
- Abuse
- Troll
0 • Off Topic Disagree Agree LikeI'll post back on the results.
- Spam
- Abuse
- Troll
0 • Off Topic Disagree Agree Like1) Engine Surge while in Drive and stopped at stop signs and lights. Shifting into neutral stops the surging and idle stabilizes.
2) Engine occasionally stalls or almost stalls when driving very slowly like through a parking lot.
3) Engine power is jerky at all speeds (used to be just at slow speeds but getting worse) unless you are deep into the throttle at higher RPM (like 3,000-4,000 + ).
4) Accelerating from a stop it often times wants to cut out and you have to feather the throttle to get it to go like it should.
- Spam
- Abuse
- Troll
